Woody Posted March 16, 2025 Posted March 16, 2025 Noticed that p6 is not sending hd video only getting sd. I factory reset and still not putting out hd. Thought it was my tv settings so i plugged in my 4900 and tv automatically went hdr10.. running current firmware on p6. I also went in and chamged the hd setting from auto to hd . Quote
dishuser Posted March 16, 2025 Posted March 16, 2025 are you using the hdmi cable that came with it? Quote
Woody Posted March 16, 2025 Author Posted March 16, 2025 Yes i am getting beta updates no i am not using tge hdmi supplied with it as it is too short. If u look at he two picss the first one is the p6 and second is the 4900. Same hdmi cable for both. So if tge 4900 will do hdr 10 then it is not the hdmi cable Quote
nbs. Posted March 16, 2025 Posted March 16, 2025 58 minutes ago, Woody said: Yes i am getting beta updates no i am not using tge hdmi supplied with it as it is too short. If u look at he two picss the first one is the p6 and second is the 4900. Same hdmi cable for both. So if tge 4900 will do hdr 10 then it is not the hdmi cable Since you are on beta you should be messaging allaboutbuzz Quote
Woody Posted March 16, 2025 Author Posted March 16, 2025 If it will do hdr 10 on 4900 it should on the p6.. i did just try the one supplied with it and still only sdr Quote
