Woody Posted yesterday at 03:39 AM Posted yesterday at 03:39 AM The clear cache button in the free up stoage menu does not work. I can clear cache by going into imternal storage menu and clearing cache that way but under the free up storage menu it does nothing Quote
Emporium Posted yesterday at 03:57 AM Posted yesterday at 03:57 AM Did you go into the Apps menu, and select BuzzTV app and the Clear cache for the app instead. Quote
Woody Posted yesterday at 04:09 AM Author Posted yesterday at 04:09 AM Yes it works that way and by going into internal storage. Im just saying if u go to the free up storage menu and try to clear cache that way it does not work Quote
dishuser Posted yesterday at 04:23 AM Posted yesterday at 04:23 AM 13 minutes ago, Woody said: Yes it works that way and by going into internal storage. Im just saying if u go to the free up storage menu and try to clear cache that way it does not work what does it show on right hand side? Quote
Woody Posted yesterday at 06:23 AM Author Posted yesterday at 06:23 AM When u go to use this option to clear cache it does nothing Quote
dishuser Posted yesterday at 06:39 AM Posted yesterday at 06:39 AM it may be an android 13 thing because the x5 ss is the same as well I'll try android 9 and 11 tomorrow Quote
Woody Posted 21 hours ago Author Posted 21 hours ago I have 4900 that works fine.. as u have to go to internnal storage menu to clear cache so sounds like it us android 13 issue not a big deal as u can clear cache by going into either the app menu or internal storage menu. Just wanted to bring it to tge buzz teams attention Quote
Emporium Posted 21 hours ago Posted 21 hours ago Android 11 does nothing either. You can see how much it uses, click on it, and does nothing. Easiest way to clear all cache would be to boot into recovery mode, and wipe the /cache partition. I do not recommend it for the average person. Typically you should just be clearing the cache on a specific app. Out of curiosity, and even on my Pixel 7, running Android 15, there is no way to clear ALL cache in one shot. Quote
Woody Posted 17 hours ago Author Posted 17 hours ago Oh well it is what it is. Lol. Still loving my p6 tho Quote
