freeze fix by changing video format from automatic.
So my neighbour was having video issue with freezing on live TV (*****). This is only happening on certain TV brands, one being Sony the other LG both smart.  All of his other neighbour with different brand are fine.
We tried switching video format in configuration from Automatic to TS and it works well now. Question is should I tell him to run HLS or TS. I am wondering if it's certain TV's don't work well with the Automatic feature?
Edited by allaboutbuzz
Can't mention servers
59 minutes ago, jets said:
So my neighbour was having video issue with freezing on live TV (wicked). This is only happening on certain TV brands, one being Sony the other LG both smart.  All of his other neighbour with different brand are fine.
Stream format has nothing to do with the brand of TV you're using
  • Like 3
So what would cause one user to freeze but not the other? Changing from automatic to the one seemed to fix it. I actually told them to switch to HLS now.
Thanks for edit.
Thanks for edit.
maybe they're using the other video player
Thanks for edit.
Changing stream format would change the type of stream the server sends
so yes HLS may be freezing but TS isn't
And auto by default uses HLS first, but if a server doesn't have HLS it will automatically use the next available format
In your first post you said that freezing happened on different TV brands, which doesn't make sense. As a TV brand has nothing to do with channels freezing
I use the same server as OP
