Problème de disque dur externe sur BuzzTV X5 SuperSport
J'avais un xrs 4900 et j'ai acheté BuzzTV X5 SuperSport j'ai pris mon disque dur externe WD et je les mi sur le x5 et ilme dit qu'il est ejecter je les formater et toujour ejecter pourquoi qu'il ne fonctionne pas
COPY/PASTE of my previous answer in other thread 🙂
I just tried my WD 2TB "My Passport" and had no issues.  Also tried a 2TB WD "My Passport ULTRA", also no issues.
I also tried with a Seagate Backup Plus Slim 1TB external and that would always give me "ejected".  I connected it to my Windows PC, and I opened a command prompt and then started DISKPART.  From DISKPART> prompt, I did a "LIST DISK" to identify my USB drive.  Then I did a "select disk 3", since that was the disk number of my USB disk.  The did a "LIST DISK" again to ensure that DISK 3 was selected.  Then I did a "clean" to wipe everything from the disk (including MBR).  Ejected disk, then went into Disk Manager (diskmgmt.msc).  Re-connected my USB disk.  Then it show up as "not initialized" (which is good).  Right click the not-initialized box on the left, and select "initialize disk" and choose as "MBR" (not GPT).  Then right click the allocated space, and select to "create a new Simple Volume".  And when you get to the filesystem type, don't format as NTFS, select exFAT.  Eject drive, plug back into X5 SS and it works perfectly again.
Edited by Emporium
merci bien centre commercial , mais c est trop compliquer pour moi , j aimmerais quelque chose de plus simple. Aussi j ai mi une cle usb de 16 gig et il la reconnu , mais pas mon disque dur externe de 1 t
did you hook it up to a pc and format it exfat?
oui je l ai formater sur mon pc ( windows 10) et je les formater en exfat et en ntfs et sa ne fonctionne toujour pas mais ma cle usb fonctionne meme apres formatage
Aussi j ai telecharger le logiciel rufus et il ne detecte pas mon disque dur externe mais il detecte une cles usb  il doit y avoir un petit probleme a avec le disque dur externe (WD un element 1 to et l autre Passport Ultra de 2 To)
The procedure is not really that complicated if you take the time to read it, step by step.
Formats and volume identifiers will vary from one disk to another and even if you get a new disk, you still risk not having it recognized.
Not every device will like a Windows centric formatting. Just like Windows would not recognize any EXT3 or EXT4 filesystems, or other partitions Linux or Android could throw at it.  You can't expect Android to recognize the hundreds of variation Windows has.
