TKlondon Posted 20 hours ago Share Posted 20 hours ago Ive noticed a few times loss of sound, i noticed it when i watching a number of youtube videos via the YT app. the only way to get sound back is to reboot the box by pressing power for a few soconds. trying to adjust the volume level or mute , has no effect. Its not a big problem for me as i can restart the box, but it might be of some use for the developers. Quote Link to comment Share on other sites More sharing options...
DRAG00N519 Posted 19 hours ago Share Posted 19 hours ago When you go to settings, and then device preferences and scroll down to decode & bitstream and click on it under audio device which one of the three options is selected? 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted 18 hours ago Share Posted 18 hours ago 32 minutes ago, DRAG00N519 said: When you go to settings, and then device preferences and scroll down to decode & bitstream and click on it under audio device which one of the three options is selected? That would depend on your hardware Quote Link to comment Share on other sites More sharing options...
DRAG00N519 Posted 18 hours ago Share Posted 18 hours ago 35 minutes ago, nbs. said: That would depend on your hardware Correct but I find when using HDMI Passthrough some apps work, and some don't when I use the decode option everything seems to be fine I was just wondering if their device is set to HDMI Passthrough by default, and that might be the issue Quote Link to comment Share on other sites More sharing options...
TKlondon Posted 16 hours ago Author Share Posted 16 hours ago it was on hdmi pass through, ive changed to decode and will test 2 Quote Link to comment Share on other sites More sharing options...
