Justin Posted October 7, 2024 Posted October 7, 2024 I get errors refusing playback on prime video and Hulu on buzztv classic Also will the classic get android 14 Quote
dishuser Posted October 7, 2024 Posted October 7, 2024 and this is where you post The Classic 1 Quote
Justin Posted October 7, 2024 Author Posted October 7, 2024 I'm telling you it doesn't nothing plays it just sits there loading Quote
dishuser Posted October 7, 2024 Posted October 7, 2024 and I'm telling you that has nothing to do with buzztv 5 1 Quote
Justin Posted October 7, 2024 Author Posted October 7, 2024 And I'm telling you it doesn't work on the classic 2 Quote
dishuser Posted October 7, 2024 Posted October 7, 2024 prime worx on mine maybe you need a different version and to learn where to post Quote
Emporium Posted October 8, 2024 Posted October 8, 2024 Try to understand. As DU mentioned, Buzztv5 is an APP on your Buzz Classic. The issue you are describing has NOTHING to do with BuzzTV 5. BuzzTV 5 is what allows you to watch LiveTV, VOD, TV Series, and record, etc.. Any further discussion regarding this issue should be moved over to the Classic thread. 1 Quote
dishuser Posted October 8, 2024 Posted October 8, 2024 and I provided the link in the 3rd post 1 1 Quote
