razor07 Posted September 4, 2024 Posted September 4, 2024 I am trying to restore audio to my stremio app, which was lost on recent update, which reset do you recommend. I deleted the app and reinstalled thinking that would work but did not. Quote
Emporium Posted September 4, 2024 Posted September 4, 2024 Hard reset is obviously the best if you can. BUT having said that, buzz has acknowledged that they have reproduced audio issues with other 3rd party apps also, so maybe you'll want to hold off until the next OTA update. The issues may be very well related. In the meantime, maybe you can try different external 3rd party players and use those for stremio (like VLC, MXPlayer, HBPlayer, etc..). 1 Quote
razor07 Posted September 4, 2024 Author Posted September 4, 2024 ok thanks for info, will give it a try. Quote
