Chris1 Posted August 28, 2024 Posted August 28, 2024 I hooked up a sata drive using a usb to sata adopter and I got the massage to let the ex explorer to use it but it doesn't show up in the settings storage it format the drive and it worked on my u5 but the p6Â Quote
Chris1 Posted August 28, 2024 Author Posted August 28, 2024 Sorry I forgot i do a tread all ready allaboutbuzz suggest to share it in the forum because I am still having the problem Quote
whacked Posted August 28, 2024 Posted August 28, 2024 try formatting the drive thru SwissKnife formatting tool. You can find a copy online easy enough. 1 Quote
Emporium Posted August 29, 2024 Posted August 29, 2024 I tried using 2 different SATA SSD (1 intel, and one Samsung) using various adapters. The basic USB to SATA simple adapters, which are 1 or 2 USB pigtails off a SATA connector, at least the 2 models I have do not work at all. They just don't see any drive. In Storage under settings, you don't even see a blip when you plug it in. I suspect this has to do with the way the USB bridges in these units handle the drives. Then I tried with a few different powered USB disk docks (2 models from Startech). With drives configured with MBR and formatted as single exFAT partition, the drives are seen, but as soon as you plug them in, they show up under the storage settings menu, but then go to "safely ejected" immediately. I even tried to do a "full format" instead of just quick format, and made no difference.  Then just out of curiosity, I decided to reformat the drives in NTFS (the only other available option on my W10 machine) and then put them back in the dock and they were seen, and I even added them as my PVR destination and recorded on them without an issue.  I'm surprised that Android box preferred NTFS over exFAT, but it could have something to do with kernel modules, so not sure. USB storage is definitely pickier on the P6. But some do work fine. The compatibility of more USB media, is surely something for them to work on in future firmware.  6 Quote
