44 minutes ago, Maestro701 said:
I need to try the external drives for a change, I have a couple knocking around. I use an SD card.
but they're not using an external drive 😉
  • 3 weeks later...
4 minutes ago, superjrbomb1970 said:
you have too do a bit of resurch becose the buzztv xrs4900 has a maxx 6tb hdd limit you can in stall a 6tb drive in i have a samsung 6tb qvo drive in my xrs4900 with no problems at all
you have it inside sata holder or are you using usb?
