Lawrence Calhoun Posted December 23, 2023 Posted December 23, 2023 How can i plug a flash drive in and play movies on VLC Quote
Emporium Posted December 23, 2023 Posted December 23, 2023 When you launch VLC, if you scroll down, you will see your USB device and you can then browse it and play whatever you want. I do it all the time. However that assumes that when you first launched VLC (when you got your box), you gave VLC permission to access files on your device. If not, you may need to play with permissions (or just uninstall and reinstall VLC and then accept the permission request when you asked at first launch). 1 Quote
Lawrence Calhoun Posted December 23, 2023 Author Posted December 23, 2023 Thank you i'll give it a go Quote
