Can not connect to wireless....
I suffer from a lot of lag and passing. It only works with ethernet. It does not connect to wireless. Can anyone help?
What router are you using ?   Does your router allow you to disable "band steering" (some call it differently).  Basically to allow you to separate 2.4Ghz and 5Ghz band, instead of allowing the router to announce one SSID and have it decide what to use.
Here is the data:
Router IPv6 status:
Enabled
IPv6 network status:
Disabled
IPv6 WAN details
Global unicast address:
Not available
http://192.168.1.254/images/u686.png
http://192.168.1.254/images/context_help_icon_u703.png
Global unicast prefix / length:
Not available
Link local address:
Not available
Remote link local address:
Not availablehttp://192.168.1.254/images/context_help_icon_u703.png
DNS:
IPv4 Only
IPv6 LAN details
Not availableULA prefix / length:
Not available
Unfortunately most all-in-one modem/routers provided by the ISP are usually not that great for WiFi (even here in North America).  They are super basic and are barely up to the job.
The setting you are looking for, would be under the "Wireless settings".  There is nothing WiFi in the settings you posted above.  It would something with the 2.4Ghz and 5Ghz bands.
Having said that, I myself have a more commercial grade setup at home ,but even then, for most of my media boxes ,I always have them wired, it is just more stable.
