Quote from new context sensitive help which will be available in upcoming buzztv 5 updates:  "Force the use of Time Shift on LiveTV channels with built-in Catch up"
3 hours ago, allinghj said:
If you go to PVR Options, there's one called "Force USB TS on/off". Does anyone know what this does?
it tells you what it does when you hilite it
Pretty sure that option is not on the current public release (5.0.799) yet 🙂
1 hour ago, allinghj said:
Wow, that's as clear as mud. If anyone can expand on this please do so.
Typically if a channel has Catchup available on the server, if you try to go back a few minutes or whatever, it uses the Catchup option.   Enabling this option forces the system to ignore the Catchup stream and use the TS buffer on your external media instead (like for all other channels that don't have catchup).
Edited by Emporium
