Iceman Posted November 2, 2021 Posted November 2, 2021 I installed an SSD drive into the buzz TV XRS 4900. When I look at storage it shows me that it's there but it says it has been safely ejected. Can anybody tell me what I'm doing wrong? Appreciate any help. Quote
allaboutbuzz Posted November 2, 2021 Posted November 2, 2021 1 hour ago, Iceman said: I installed an SSD drive into the buzz TV XRS 4900. When I look at storage it shows me that it's there but it says it has been safely ejected. Can anybody tell me what I'm doing wrong? Appreciate any help. Where did you format it, on the box or on a PC? Try formatting it on a PC first, to NTFS Then plug it back into the box. Quote
dishuser Posted November 2, 2021 Posted November 2, 2021 does format show as an option? what size is drive? Quote
Iceman Posted November 2, 2021 Author Posted November 2, 2021 On the box. Now it recognizes it. But when I go to record using buzz TV's live tv player. It only gives me the option of internal storage . There's no way I and switch it over to the SSD drive 1 Quote
allaboutbuzz Posted November 2, 2021 Posted November 2, 2021 4 minutes ago, Iceman said: On the box. Now it recognizes it. But when I go to record using buzz TV's live tv player. It only gives me the option of internal storage . There's no way I and switch it over to the SSD drive You format it as Internal Storage or External Storage? Quote
allaboutbuzz Posted November 4, 2021 Posted November 4, 2021 On 11/2/2021 at 6:45 PM, Iceman said: External. Format it on a PC first to NTFS Than Format it on the box as external storage It should work after doing this. Quote
Maestro701 Posted November 5, 2021 Posted November 5, 2021 On 11/2/2021 at 6:32 PM, Iceman said: On the box. Now it recognizes it. But when I go to record using buzz TV's live tv player. It only gives me the option of internal storage . There's no way I and switch it over to the SSD drive Click the PVR button on remote and change storage right at the top. Quote
