Anglishplz Posted October 5, 2021 Posted October 5, 2021 When recording with pvr I get no sound/audio on playback? I've tried resetting the device back to its default state thinking it may be an incorrect setting but still nothing. It doesn't matter if I'm recording to the internal storage or using a USB flash drive or USB hdd. What else could it be? Quote
nbs. Posted October 5, 2021 Posted October 5, 2021 (edited) what are the audio options when you hit green button for audio while pvr is playing? Edited October 5, 2021 by nbs. Quote
Anglishplz Posted October 5, 2021 Author Posted October 5, 2021 It says audio is disabled with a check mark by it, I can't uncheck it. Quote
dishuser Posted October 5, 2021 Posted October 5, 2021 On 10/5/2021 at 6:18 PM, Anglishplz said: It says audio is disabled with a check mark by it, I can't uncheck it. Expand try the other player 1 1 Quote
dishuser Posted October 5, 2021 Posted October 5, 2021 On 10/5/2021 at 6:34 PM, Anglishplz said: Other player? Expand menu/settings/configuration Quote
dishuser Posted October 5, 2021 Posted October 5, 2021 also where it showed disabled did it have track 1 below it? Quote
Anglishplz Posted October 5, 2021 Author Posted October 5, 2021 Thank you! Switching player fixed it. 1 Quote
