Andy C Posted July 13, 2021 Share Posted July 13, 2021 Typically I get recording in ts format but from time to time the box records or tries to record in mkv format and fails most of the time. Anybody knows how to rectify or force it to stay in TS only. XRS4500 with unofficial upgrade to 5 ( works very well except this mkv issue) Thanks Quote Link to comment Share on other sites More sharing options...
dishuser Posted July 13, 2021 Share Posted July 13, 2021 maybe that's the problem is that you're not using buzztv 4 Quote Link to comment Share on other sites More sharing options...
Andy C Posted July 13, 2021 Author Share Posted July 13, 2021 I don't think so........I has been using it for 3 months, it is fantastic. The problem is specific to some channels only with one provider used as a backup service and it is consistent on my 2 boxes. Viewing is perfect. It fails after "waiting for a datastream" message. Also +6hrs channels record fine in mp4. I am just trying to find out if there is something which can help. The boxes(2) perform very well otherwise Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted July 16, 2021 Share Posted July 16, 2021 On 7/13/2021 at 10:11 AM, Andy C said: Typically I get recording in ts format but from time to time the box records or tries to record in mkv format and fails most of the time. Anybody knows how to rectify or force it to stay in TS only. XRS4500 with unofficial upgrade to 5 ( works very well except this mkv issue) Thanks It records in TS or MKV depending on the format the stream you're watching is in. There is no way to force it in TS 1 Quote Link to comment Share on other sites More sharing options...
