lailanis Posted June 2, 2021 Share Posted June 2, 2021 Hi I'm still playing with my XRS 4900 and on a learning curve. Thx for the forum and developers that listen to the feedback I have some questions which are somewhat related. When I turn on auto switch to best resolution, it default into 2160p60hz which I'm fine with but there are content (mainly non north american (europe, north africa, middle east) either iptv or movies that are 50hz but I don't see buzztv auto switch refresh rate when I change from 60hz content to 50hz content, what ever is set stays the same, if it's set to 60hz, all content is played 60hz, if I switch off auto switch to best resolution and set resolution to 2160hz50hz, all content is played at 50hz You know some movies are run in 24 or 25hz, so it's good to have a box that auto switch refresh rate to avoid stuttering and frame drop here and there I know it wasn't doable with old android versions but I think they fixed that recently, even other competitors have that added and they don't even have full android TV but just modified android mobile or whatever it's called I also saw a display mode named 4k2k-smpte (not sure what smpte stands for) Thanks for looking into this, or maybe I'm missing something and needs some clerance 1 Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted June 2, 2021 Share Posted June 2, 2021 44 minutes ago, lailanis said: Hi I'm still playing with my XRS 4900 and on a learning curve. Thx for the forum and developers that listen to the feedback I have some questions which are somewhat related. When I turn on auto switch to best resolution, it default into 2160p60hz which I'm fine with but there are content (mainly non north american (europe, north africa, middle east) either iptv or movies that are 50hz but I don't see buzztv auto switch refresh rate when I change from 60hz content to 50hz content, what ever is set stays the same, if it's set to 60hz, all content is played 60hz, if I switch off auto switch to best resolution and set resolution to 2160hz50hz, all content is played at 50hz You know some movies are run in 24 or 25hz, so it's good to have a box that auto switch refresh rate to avoid stuttering and frame drop here and there I know it wasn't doable with old android versions but I think they fixed that recently, even other competitors have that added and they don't even have full android TV but just modified android mobile or whatever it's called I also saw a display mode named 4k2k-smpte (not sure what smpte stands for) Thanks for looking into this, or maybe I'm missing something and needs some clerance The Display setting in Android settings is for Resolution It only determines automatically the best resolution your TV can support What you're referring to is Auto Frame Rate to match the content that you're currently watching We do not have this feature right now. Its something we plan to add at a later date though. 3 1 Quote Link to comment Share on other sites More sharing options...
lailanis Posted June 2, 2021 Author Share Posted June 2, 2021 5 minutes ago, allaboutbuzz said: The Display setting in Android settings is for Resolution It only determines automatically the best resolution your TV can support What you're referring to is Auto Frame Rate to match the content that you're currently watching We do not have this feature right now. Its something we plan to add at a later date though. I see It'll be great to have auto refresh rate. Thx a bunch for quick reply 1 Quote Link to comment Share on other sites More sharing options...
