Reech Posted May 16, 2021 Share Posted May 16, 2021 Not having much luck recording on this device it keeps putting up thumbnails of the recording but files corrupted? Quote Link to comment Share on other sites More sharing options...
dishuser Posted May 16, 2021 Share Posted May 16, 2021 and this makes #4 Quote Link to comment Share on other sites More sharing options...
Reech Posted May 16, 2021 Author Share Posted May 16, 2021 What's your problem bro!! Quote Link to comment Share on other sites More sharing options...
dishuser Posted May 16, 2021 Share Posted May 16, 2021 surprised you haven't started a 5th thread for same topic...lol Quote Link to comment Share on other sites More sharing options...
nbs. Posted May 16, 2021 Share Posted May 16, 2021 (edited) 19 minutes ago, Reech said: What's your problem bro!! You have started multiple threads on the same topic You were asked after you started the second one to stick to one thread which you ignored Edited May 16, 2021 by nbs. Quote Link to comment Share on other sites More sharing options...
Reech Posted May 17, 2021 Author Share Posted May 17, 2021 How do I delete the thread? Quote Link to comment Share on other sites More sharing options...
Reech Posted May 17, 2021 Author Share Posted May 17, 2021 Hey, does anyone know what the audio setting should be at? Video and audio not matching up. Quote Link to comment Share on other sites More sharing options...
nbs. Posted May 17, 2021 Share Posted May 17, 2021 try changing media player or refresh your server audio setting wont affect your sync 1 Quote Link to comment Share on other sites More sharing options...
Reech Posted May 17, 2021 Author Share Posted May 17, 2021 U mean use mx player? This setting has corrected the audio and video sync problem. Quote Link to comment Share on other sites More sharing options...
dishuser Posted May 17, 2021 Share Posted May 17, 2021 there are 2 players in the buzz app default and secondary in live tv menu/settings/configuration 1 Quote Link to comment Share on other sites More sharing options...
Maestro701 Posted May 17, 2021 Share Posted May 17, 2021 12 hours ago, Reech said: U mean use mx player? This setting has corrected the audio and video sync problem. Are you using an external device as a speaker, like a sound bar? Quote Link to comment Share on other sites More sharing options...
