2jay2 Posted April 29, 2021 Posted April 29, 2021 Hi just got 2 buzz vidstick max and set everything up. If I'm using the remote and stop using it when I try to use it again it will not work at all. I had to do a reset on the stick repair the remote and then it will work...as soon as I stop using it and try again it will not work. This is happening on both sticks Quote
nbs. Posted April 29, 2021 Posted April 29, 2021 If you have the ir extender connected it should still work and you would not have to reset the box Quote
2jay2 Posted April 29, 2021 Author Posted April 29, 2021 1 minute ago, nbs. said: If you have the ir extender connected it should still work and you would not have to reset the box I know and that's what I'm doing now but one of the best benefits of buzz over let's say the formula z box is the remoteĀ that'sĀ Ā Bluetooth Quote
nbs. Posted April 29, 2021 Posted April 29, 2021 I know ,just trying to provide a temp solutionĀ Quote
2jay2 Posted April 29, 2021 Author Posted April 29, 2021 23 minutes ago, nbs. said: I know ,just trying to provide a temp solutionĀ I really appreciate it..thanks for your suggestion Quote
dishuser Posted April 30, 2021 Posted April 30, 2021 do you have any other bluetooth devices nearby? 1 Quote
2jay2 Posted April 30, 2021 Author Posted April 30, 2021 10 hours ago, dishuser said: do you have any other bluetooth devices nearby? Yes I do Quote
dishuser Posted April 30, 2021 Posted April 30, 2021 1 hour ago, 2jay2 said: Yes I do turn them off and see if remote stays paired Quote
