ger482 Posted December 16, 2022 Share Posted December 16, 2022 I have an issue with the epg not automatically populating on both my 4500s and 4900. after roughly 2 days it's empty and you have to scroll through all the channels to repopulate. any way to fix this? thanks Quote Link to comment Share on other sites More sharing options...
Emporium Posted December 16, 2022 Share Posted December 16, 2022 (edited) I have 2x 4900 boxes and I don't have this issue on either one or the other (on 2 different servers). Populates daily. I haven't checked my 4500 in a while however. Have you tried clearing the BuzzTV5 cache, just in case ? As a reference, what version of BuzzTV are you running on the 4500 and 4900 ? Edited December 16, 2022 by Emporium Quote Link to comment Share on other sites More sharing options...
ger482 Posted December 16, 2022 Author Share Posted December 16, 2022 I have the latest update from 12-9-22 but don't get the 7 day epg only 2 days Quote Link to comment Share on other sites More sharing options...
Emporium Posted December 16, 2022 Share Posted December 16, 2022 And you are sure that your service provider has 7 day EPG ? Just curious, have you tried with another app (stbemu, smarters, etc..), just as a test to see if you get 7 day with the other app ? 1 Quote Link to comment Share on other sites More sharing options...
ger482 Posted December 20, 2022 Author Share Posted December 20, 2022 getting provider info. the system is MAC based Quote Link to comment Share on other sites More sharing options...
Emporium Posted December 21, 2022 Share Posted December 21, 2022 If your sub is MAC based, you can easily just install STBEmu to check and see how much EPG it gets. Quote Link to comment Share on other sites More sharing options...
Maestro701 Posted January 1, 2023 Share Posted January 1, 2023 Sometimes a reboot does the trick Quote Link to comment Share on other sites More sharing options...
