BigBision Posted October 28, 2019 Posted October 28, 2019 1. Select Settings 2. Select Device Preferences 3. Scroll Down and Select Sound 4. Click on System sounds By Default The System Sounds is always On, by clicking OK on your remote you will turn off the Sound notification. 5. Press Back till you are in Main Screen Enjoy! 1
