I have 3 buzz tv boxes side by side running on 3 separate tvs but when I change to a channel on one box it changes the others. I was wondering if there is any way of changing any code so the remotes will work separately?
Expand
nope
do what my bar does
place cardboard shells over the boxes
remove when you want to change channel
Edited by dishuser
