Joshuas Gems Posted November 22, 2020 Posted November 22, 2020 Hey, anyone else going through tons of batteries? I use Duracell and use the remote as IR NOT BT. My box is on all the time however I'm not using the remote all the time. My xpl3000 lasts 2-3 months but my xr4500 lasts a week at max? Quote
luvdabuzz Posted November 26, 2020 Posted November 26, 2020 do you have the backlight turned on the remote? mine was doing the same turned it off easily lasts 2-3 months now. Quote
Joshuas Gems Posted December 15, 2020 Author Posted December 15, 2020 How do you disable backlight? Quote
dishuser Posted December 15, 2020 Posted December 15, 2020 (edited) press and hold blue button until it turns off instructions are on back of remote Edited December 15, 2020 by dishuser Quote
