BigBision Posted October 26, 2020 Posted October 26, 2020 I am sure you come across this issue, a guest at your house or a kid for fun or Prank change your language to something you can not read. here is how easy it is to fix it back. 1. From Main Screen Scroll down to Settings and Select it. 2. Scroll Down and Select Device Management. 3. Scroll down and Select Language. 4. Scroll down and Select English ( USA ) Then Click on back button a few times till you are back to main screen, and you are set. Enjoy!.
