BigBision Posted August 31, 2020 Share Posted August 31, 2020 1. Long Press [ TV Power + OK ] keys for 3 seconds Until you see the blue light LED turns Solid Red. 2. Press the key to be programmed. Example [ TV Power ] The Blue LED begins to blink. 3. Aim the Remote to the front of the TV Remote( distance less then 3CM ) 1) Press Power button on Buzztv Remote 2) Press Power button on your TV remote. 3 ) You will see that Light will blink 3 times 4. Press Power on Buzztv TV remote to sync the code. Now test your Buzztv remote with your TV to make sure the power works. Also you can same type of steps for Source button on buzztv remote. Link to comment Share on other sites More sharing options...
