gmeades Posted August 13, 2020 Posted August 13, 2020 All the other keys and the keyboard, and the air mouse, work properly on my ARQ-100, but the power button does nothing. I've tried entering "learning mode", but that hasn't done anything. Has anyone run into this and found a solution to get the power button to function on the ARQ-100...?
BigBision Posted August 13, 2020 Posted August 13, 2020 As i can check you are spamming all over the forums with questions, but after reading most of your post i see that you have VidStick, and VidStick do not have IR sensor built in, and when you turn on Bluetooth The IR Indicator turns off, even if you hooked up the IR extender. So On ARQ-100 The Green Power button only works with IR and not USB dongle. so the remote works 100% no problems with it.
