BigBision Posted July 9, 2020 Share Posted July 9, 2020 This Tutorial should show you how to use IR portion of your Remote, and how to change from Bluetooth Remote to IR. 1. Make sure you have your IR extender ready, and make sure VidStick is Turn on and YourTV is On. 2. Hookup the IR Extender to your VidStick aka ST4000. Using your BT-100 Remote 3. From the Main screen Scroll and Select Settings 4. Scroll down and select Remote and Accessories. 5. Select BT-100 6. Scroll down and Select Unpair 7. You see a page will ask you to Select OK 8. Now it is unpaired and you are using Your Remote as IR remote. Point your remote to the IR Extender and press back till you are back to the main screen. Enjoy your VidStick with IR Remote. Link to comment Share on other sites More sharing options...
