Orion1309 Posted June 15, 2020 Posted June 15, 2020 how do you reset the vid stick 4000 from the stick itself Quote
whacked Posted June 15, 2020 Posted June 15, 2020 (edited) Are you talking about a pin-hole reset or the reset found in the menu selection. The pin-hole method is not the actual reset thou. It's the method to take your device into Recovery Mode and then the reset function is found once in the Recovery Mode. Follow BigBison's post for the Recovery method. It's a 4500 model but the procedure is same for the VidStick except the pin-hole placement. With the VidStick, look just below the IR port is where the pin-hole is found. Follow BigBison's post for the reset found in the menus. It's a 4000 model but the procedure is same for the VidStick Edited June 15, 2020 by whacked 1 Quote
