Hello All,
Has anyone noticed that if you use the GREEN button on remote and save a VOD  for watching later.  But if its been few months and then you  get back to it by accessing your Favorites list - and hit PLAY on it - it does not stream.
Workaround here is to remove it from favorites. Search that VOD again and start streaming.  Is there any fix for this?
Thanks!
7 minutes ago, Hhh said:
Hello All,
Thanks!
tell your service to stop moving them around
40 minutes ago, Hhh said:
Aha. So I didnt realize that its the service that moves them around. and so the soft link doesnt stream?
what you saved as a favourite no longer exists on that server
it's been moved to a different server
  • 2 weeks later...
