1.  Long Press [ TV Power + Source ] keys for 3 seconds
Until you see the blue light LED turns Solid Blue.
2. Press the key to be programmed. Example [ TV Power ]
The Blue LED begins to blink.
3. Aim the Remote to the front of the TV  Remote( distance less then 3CM )
1) Press Power button on Buzztv Remote
2) Press Power button on your TV remote.
3 ) You will see that Light will blink 3 times
4. Press Power on Buzztv TV remote to sync the code.
Now test your Buzztv remote with your TV to make sure the power works.
Also you can same type of steps for Source button on buzztv remote.
  • Confused 1
This topic is now closed to further replies.
