I would love to cut the cable TV,  Now I need some advice of what I should get , WIFI-Internet , how strong or Mgb do I need , Do I need to get twice IPTV  FOR 2 buzz tv boxes,  And is there any help Available if I have problems with connecting the TV Boxes, I would appreciate a little note from you, to led me know , which boxes are the right ones , and so on, and so on !!
I need help with cutting my cable and Wifi ,
also do I need a advice which  of your TV Boxes should I get, how much Mgb should I require to  run my boxes ,do I install 2 IPTV  FOR MY 2tv  or because thy are having a cable splitter would 1IPTV be enough!!
would help also be available for any connection help??????????
Love to hear from you !  Best way will be by phone if possible, I’m to old for this typing 🙏
Sincerely M.H.
it depends on what you plan on using boxes for
you can see the lineup here
https://buzztvglobal.com/
for iptv you need unlimited bandwidth and a speed of around 10 mb/s
