recently they updated the plex app new version..but is causing problems..when trying to play any media from library ..plex shuts down..is only doing it on xrs4500..i have a shield has no problem..also on plex tv app no problems...did a fresh uninstall on plex & tried older versions of plex but has horrible mobile display not functional with buzz box..try to use tv display on plex but doesnt work
i would say it wasnt a plex problem because it only happens on the xrs4500 box & not on other devices..... it wasnt doing this before the plex update .. please help..love the xrs4500 but this hurts the use !!
I finally figured it out...the xrs4500 does not work well will the lastest plex app..had to go back in a march app of plex to install...now it it working smooth..also it lets you use the tv layout not the mobile layout in the march version..the new plex update wont let you go into the tv layout..by the way im using the march 8th version of plex
  • Thanks 1
