hi i am after some help i had to reset my st4000 vidstick but when it rebooted it the remote wouldnt pair with the stick but i got it to work with the IR dont know how i did it lol but is there anyway i can get back to using it without the IR?many thanks
37 minutes ago, marcoose said:
hi mate ive got it working with the ir connected but i want to have it working with out the ir connected ?
you're just repeating yourself
ive tried to pair via the screen with the remote on it if thats  any help? thats the only way i know how to do it
Edited by marcoose
5 minutes ago, marcoose said:
yes with ir sensor in
point it at the stick not the sensor
if it fails try again
it sometimes takes more than one try
when mine failed first time I put remote inches away from stick and second attempt worked
hi mate just rebooted stick tried it again and its saying it paired under remotes and accecessories ive now got bluetooth on add accessories and buzztv bt-100 it says connected then click on it and it says change name unpair and battery 77% does it need a name or not ?cos if i pull the ir out the remote dont work?
