G2P Posted December 10, 2019 Posted December 10, 2019 Hi I got audio sync problem (audio legging about 1 to 2 sec ) on live channels , i tried Default and secondary player but same issue Default player get more often and more legging vs Secondary Player any suggestion or settings? Thanks Quote
Stugots Posted December 17, 2019 Posted December 17, 2019 On 12/10/2019 at 5:30 PM, G2P said: Hi I got audio sync problem (audio legging about 1 to 2 sec ) on live channels , i tried Default and secondary player but same issue Default player get more often and more legging vs Secondary Player any suggestion or settings? Thanks Try today's update to see if the problem gets resolved. Quote
Nelutz Posted December 18, 2019 Posted December 18, 2019 On 12/10/2019 at 5:30 PM, G2P said: Hi I got audio sync problem (audio legging about 1 to 2 sec ) on live channels , i tried Default and secondary player but same issue Default player get more often and more legging vs Secondary Player any suggestion or settings? Thanks It happens on all the channels?because I have this problem to on some channels but is from the server is not from the Buzztv players Quote
Shoma Posted December 18, 2019 Posted December 18, 2019 10 hours ago, Nelutz said: It happens on all the channels?because I have this problem to on some channels but is from the server is not from the Buzztv players Same here. And it happens on different players on the same channel. So it must be the server. Quote
Nelutz Posted December 19, 2019 Posted December 19, 2019 Seams like the default player is a problem, yes is getting out of sync more often ,the secondary player is the right option right now Quote
G2P Posted December 19, 2019 Author Posted December 19, 2019 some channels but same on other server, default and 2nd player both has the same problem Model 3900 has the same but when you use 2nd or 3rd player it solves the problem After recent update i do not see any audio sync problem, but i have not play enough , hope it solved i will updates you next week Quote
G2P Posted December 23, 2019 Author Posted December 23, 2019 (edited) so far no audio leg issue (audio sync)tested for 4 days Thanks Edited December 23, 2019 by G2P Quote
