Pittro Posted February 3, 2022 Posted February 3, 2022 Just got my Buzztv XRE4500...works great..im still waiting for my Buzztv 5 "2015" update..added a ticket for QUE.. Is there a way to stop running apps from home screen ? or do they just shut down after closing them Quote
dishuser Posted February 3, 2022 Posted February 3, 2022 13 minutes ago, Pittro said: Just got my Buzztv XRE4500...works great..im still waiting for my Buzztv 5 "2015" update..added a ticket for QUE.. Is there a way to stop running apps from home screen ? or do they just shut down after closing them press home button twice 2 Quote
Pittro Posted February 3, 2022 Author Posted February 3, 2022 i knew there was a trick...Thanks alot !! also is there an audio optimizer app to use.. i noticed while playing other apps like plex i have to crank up volume on the tv but when i go to live tv sound is louder ? Quote
Benfica Posted February 3, 2022 Posted February 3, 2022 1 hour ago, Pittro said: i knew there was a trick...Thanks alot !! also is there an audio optimizer app to use.. i noticed while playing other apps like plex i have to crank up volume on the tv but when i go to live tv sound is louder ? For plex can u try this : Go to SETTINGS. Go to PLEX WEB…PLAYER on the left-hand list of options . Finally uncheck NORMALIZE MULTI-CHANNEL AUDIO. Hit SAVE CHANGES. Close any videos you may have open and reload the browser window. Hope that helps! 1 Quote
Pittro Posted February 3, 2022 Author Posted February 3, 2022 ok...thanks...ill try when i get home tonight Quote
