dreamer_cast Posted July 22, 2019 Posted July 22, 2019 Hey guys, I was wondering if there was a fix or update to enable better functionality with the 3900 and the ARQ-100 remote. I find some of the buttons do nothing (Back button) while other preform the wrong function (Guide button does not bring up actual guide). Any help would be appreciated! dreamer Quote
Stugots Posted July 22, 2019 Posted July 22, 2019 8 hours ago, dreamer_cast said: Hey guys, I was wondering if there was a fix or update to enable better functionality with the 3900 and the ARQ-100 remote. I find some of the buttons do nothing (Back button) while other preform the wrong function (Guide button does not bring up actual guide). Any help would be appreciated! dreamer all the buttons for ARQ100 will work on XPL3900. either your remote has the problem or you can reload the firmware to see if this helps Quote
