JOE CARO Posted 10 hours ago Posted 10 hours ago After Dec 3 2025 update I had to do a factory reset as advice , Because it was stuck on Buzztv logo. After factory reset I was able to reboot. Now I can connect to my ethernet but can't connect with WIFI. Also when adding a XC API Login for my Iptv service I get "Portal not supported message." My IPTV service info is correct also its working on other devices Quote
dishuser Posted 10 hours ago Posted 10 hours ago there was no need to start another thread thye one you first posted in was good enough Quote
