Bandit035 Posted November 30, 2019 Posted November 30, 2019 While watching live tv the picture will flicker then the sound cuts out. I need to change channel to get it to come back in. This happens very frequently. Any ideas? Quote
Nelutz Posted November 30, 2019 Posted November 30, 2019 2 hours ago, Bandit035 said: While watching live tv the picture will flicker then the sound cuts out. I need to change channel to get it to come back in. This happens very frequently. Any ideas? Same problem with me ,I think is the player that the Buzztv app using ,I've tried the second player and still the same ,they need to come up with an update or let us try the beta FW or something. Quote
Bandit035 Posted November 30, 2019 Author Posted November 30, 2019 Yes because my 3000 works fine. This box has a lot of issues. 1 Quote
Stugots Posted November 30, 2019 Posted November 30, 2019 7 hours ago, Nelutz said: Same problem with me ,I think is the player that the Buzztv app using ,I've tried the second player and still the same ,they need to come up with an update or let us try the beta FW or something. if your a beta test a new update was sent yesterday. however the micro freezing issue requires a new firmware update which were sending publicly early next week Quote
Stugots Posted November 30, 2019 Posted November 30, 2019 6 hours ago, Bandit035 said: Yes because my 3000 works fine. This box has a lot of issues. xpl3000 had issues when it first came out but within a few months after launch most bugs are ironed out. xpl3000 is android 7 which we mastered years ago and xr4000 is android 9. The dev team is doing its best to keep up with bug fixes and customers requests. 1 Quote
Nelutz Posted December 1, 2019 Posted December 1, 2019 19 hours ago, Stugots said: if your a beta test a new update was sent yesterday. however the micro freezing issue requires a new firmware update which were sending publicly early next week But I'm not a beta tester ,I wish Quote
