29 minutes ago, DRAG00N519 said:
Hey guys the ethernet port on my box is not working I tried the same cord  on a different device and it worked so I know it's not the cord is there anyway you guys can do to help me out
have same problem
at least wifi worx
8 minutes ago, sts41 said:
i am using ethernet without issue, and i did nothing other than do todays update. i have wifi turned off, but it did default to ether
It's not a problem on every box my friend bought the box as well and does not have the issue
48 minutes ago, dishuser said:
have same problem
at least wifi worx
True it's not the worst thing in the world but if it can't be fixed, I'd be fairly disappointed I really prefer to hardwire my android boxes
the only reason I ran ethernet was because my 4900 would drop wifi after 3-5 hours
it could be a bad port
I'll be honest I had the same ethernet issue on my 4900 and the staff try to help me with the issue but nothing worked so I returned it and they gave me another one and the new one had the same issue at the time that was a dealbreaker for me the only reason the ethernet port wouldn't be a dealbreaker for me this time is the box was expensive so I'll just deal with it if I have to, I'm hoping that's not the case though
