I had a similar issue a few months ago, but now that I've renewed my subscription my EPG isn't loading again. It just seems to sit on loading forever for most channels.
you don't get any epg options using mac
I use xc api and get 7 days of guide in seconds
but sure I can see how that isn't helpful 🤪
Edited by dishuser
Yeah, I was getting that too. Previously someone on this forum sent me an update that fixed the issue, but when I renewed my subscription with my provider, it broke again so I was hoping I might be able to get the same help. But I am also investigating the option of changing my account over to xc because hopefully it'd be less hassle.
epg is coming from server when using mac
unless they fix it your hands are tied using mac
plus majority of services give more than one connection using xc api or m3u so you record or download while watching a different channel
