Entertainmentoasis Posted November 23, 2019 Posted November 23, 2019 Alot of apps require you to be able to navigate to a top bar for example cyberflix, unlock your tv and others based on terrarium code. All the apps I've tried I can't get up to the top navigation top in the apps without using the mouse it's annoying. This wasn't an issue with the older buzztv I this it might be the launcher bar blocking it. Is there anyway around this? Quote
BigBision Posted November 23, 2019 Posted November 23, 2019 12 hours ago, Entertainmentoasis said: Alot of apps require you to be able to navigate to a top bar for example cyberflix, unlock your tv and others based on terrarium code. All the apps I've tried I can't get up to the top navigation top in the apps without using the mouse it's annoying. This wasn't an issue with the older buzztv I this it might be the launcher bar blocking it. Is there anyway around this? This was not addressed before, we will work on a fix. 1 Quote
DroidFusions Posted November 23, 2019 Posted November 23, 2019 This is not a problem of buzztv. It's an issue with android 9. I've tested a few boxes. Quote
Entertainmentoasis Posted December 20, 2019 Author Posted December 20, 2019 Thank you for fixing this issue in the new update. Quote
Stugots Posted December 21, 2019 Posted December 21, 2019 On 11/23/2019 at 12:21 PM, DroidFusions said: This is not a problem of buzztv. It's an issue with android 9. I've tested a few boxes. you are correct but we managed to fixed the issue in the last update. 1 Quote
