Shoma Posted November 21, 2019 Posted November 21, 2019 Is it possible to downgrade to v2? I have too many issues with BuzzTV 4 that I don’t have on BuzzTV 3000 with BuzzTV 2. The most annoying is this: I start the app and it opens the first channel, then when I change the channel, it won’t open it, just spinning. I tried the same provider on BuzzTV 3000 and works fine. Quote
Nelutz Posted November 22, 2019 Posted November 22, 2019 13 hours ago, Shoma said: Is it possible to downgrade to v2? I have too many issues with BuzzTV 4 that I don’t have on BuzzTV 3000 with BuzzTV 2. The most annoying is this: I start the app and it opens the first channel, then when I change the channel, it won’t open it, just spinning. I tried the same provider on BuzzTV 3000 and works fine. I've tried that ,but the system it doesn't let you downgrade Quote
Stugots Posted November 22, 2019 Posted November 22, 2019 BuzzTV 2 is designed for Android 7 BuzzTV 4 is designed for Android 9 We have customers asking to upgrade from 2 to 4. This is the first request to downgrade. Please email us cs@buzztv.com with your serial number to further assist you on this. Quote
Shoma Posted December 1, 2019 Author Posted December 1, 2019 I emailed support on 23rd of November and have not received a reply yet. Quote
Nelutz Posted December 1, 2019 Posted December 1, 2019 4 hours ago, Shoma said: I emailed support on 23rd of November and have not received a reply yet. Good luck they never answer u will get an answer here than trough emails Quote
Stugots Posted December 5, 2019 Posted December 5, 2019 On 12/1/2019 at 2:44 PM, Shoma said: I emailed support on 23rd of November and have not received a reply yet. did you get a reply? Quote
Shoma Posted December 5, 2019 Author Posted December 5, 2019 Yes, they pushed beta and it is working better. Still have issue with VPN and ethernet though. Quote
Stugots Posted December 5, 2019 Posted December 5, 2019 4 hours ago, Shoma said: Yes, they pushed beta and it is working better. Still have issue with VPN and ethernet though. to fix this problem requires a firmware update. were expecting to send a firmware update next week 1 Quote
NitroMike Posted December 14, 2019 Posted December 14, 2019 How can I get this done one my box. No reply one emails. Quote
Nelutz Posted December 15, 2019 Posted December 15, 2019 I think soon like this week will have an update Quote
Shoma Posted December 17, 2019 Author Posted December 17, 2019 Today's update resolved the problems. Nice work!! 1 1 Quote
