on VOD listing ...Newer Episodes on top by default
How to set by default on VOD listing ...Newer Episodes on top by default . ( i.e default list 9-0 instead 0-9 ) no extra button to press.
that's right, but it would be great if by default the new episodes on top of the VOD list without pressing Green Button and Then choosing (9-0)
Expand
changing the default new episodes list  will make some people happy and other people unhappy.  this is why we added the green button option. we can look into an option to set all episodes to show default 9-0 vs 0-9
i think most people watch latest or current episodes ,and only some who missed or started late may use from 0-9
thanks to considering an option
Edited by G2P
Expand
OR like in XPL3900, Scroll up will take you from episode one to last in backward will be great for all (no need of 0-9 or 9-0)
Expand
unfortunately its not easy to support this feature on Android 9. We're working on a solution at the moment.
  • 2 weeks later...
  On 12/5/2019 at 5:16 PM, Stugots said:
if you want to use the beta pm with your serial number. this feature is added on the beta
Expand
Thanks for updating in Beta the VOD list listed backward  (Last episode on Top)🙏
