ATTENTION: This fix ONLY works on 2018 Edition (Android 7) versions of XPL 3000.
1. Download the file onto a computer
Then transfer it onto a USB drive or SD card
Then insert into box
2. Use reset hole on the back of your 3000 to get into recovery mode on first time boot.
You will need to use a Tooth Pick or Paper Clip or something similar to do this.
3.
Once in recovery
Go to
Apply update from ext
Select Udisk which is USBDrive or SD Card depending on which one you have the Firmware on
4.Highlight the Firmware
Press Ok to install it
It will take up to 8 mins to install
5. Once finished
Select reboot
6. It will boot back into Android and everything is normal and nothing is erased
  • Thanks 1
Does not work getting Failed to verify whole-file signature
this method works 100% of the time. please retry all the steps again. is your box XPL 3000 with Android 7? if you get an error message please post a photo of it.
thank you
Guest Steve
Doesn’t work
getting messages wrong signature
Tried multiple times but invalid signature error
I am getting same error message "Failed to verify whole-file signature" and Error code 21.
Guest Same message
Same message over and over - Failed to verify whole-file signature
Expand
that error 21 means boot system differs.  it can crash.  you can wipe data clear cache before you factory reset then install the firmware on it.
" Not different brand box.  "
Edited by BigBision
wrong word in wrong place.
Guest Name_
I keep getting error 21. It does not work
Guest Steve
  On 7/21/2019 at 2:26 PM, BigBision said:
that error 21 means you have different brand or different version of the Buzztv model.
Expand
getting sam error 21, that means my box wont work anytime soon ? or its garbage now ?
What do u mean diff brand even im getting the same error 21 and says signature verification failed
Guest Buzztvisgarbage
***comments removed***
Any updates on this issue? Stuck with no TV or solution for 4 days.
Paid service. Hence it is reasonable to expect a prompt response.
Guest Kiran
Yes Im also getting the same error and the box is non working condition for last 5 days now.
Expand
Hello,
files were provided promptly. try re-downloading the file here , XPL3900 file is same as XPL3000 however the file could be corrupted when downloading originally.
Expand
try redownloading from this thread. XPL3900 / XPL3000 share same firmware but it sounds like the XPL3000 version is corrupted.
