Rinny1 Posted December 20, 2021 Share Posted December 20, 2021 Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted December 20, 2021 Share Posted December 20, 2021 16 hours ago, Rinny1 said: Same problem also !! allaboutbuzz said it’s fixed but still ongoing problem (work in progress??) small glitch kicking the sound out on default player secondary player will lock up Its fixed on Buzz 5 We cant fix it on Buzz 4 Version 4.0.522 is Buzz 4 1 Quote Link to comment Share on other sites More sharing options...
TheGhost Posted February 8, 2022 Author Share Posted February 8, 2022 Responding here should be enough they should see it! I reported it here I have done my part the issue isn't fixed though for sure. Quote Link to comment Share on other sites More sharing options...
dishuser Posted February 8, 2022 Share Posted February 8, 2022 18 minutes ago, TheGhost said: Responding here should be enough they should see it! I reported it here I have done my part the issue isn't fixed though for sure. no sound issue with my xr 4000 Quote Link to comment Share on other sites More sharing options...
Tayls Posted April 4, 2022 Share Posted April 4, 2022 Hi, I am experiencing the same issue ver 4.0.524. How can I update to Version 5 please? Quote Link to comment Share on other sites More sharing options...
dishuser Posted April 4, 2022 Share Posted April 4, 2022 34 minutes ago, Tayls said: Hi, I am experiencing the same issue ver 4.0.524. How can I update to Version 5 please? https://stbtalk.com/index.php?/forum/79-buzztv-5-beta/ 2 Quote Link to comment Share on other sites More sharing options...
TheGhost Posted September 15, 2022 Author Share Posted September 15, 2022 This issue is STILL occurring this issue has not fixed. I reported this back in 2021 and the problem still exists today. My Buzz TV XR 4000 is still experiencing the same issue the box is upgraded the latest version of Buzz TV as well. My Buzz TV Firmware is V20211111 and Current IPTV Version 4.0.530 When I do an update it says it is the latest version is installed Also do NOT tell me to reset the box I have already did that multiple times and it does not fix the issue! I have already factory reset it multiple times and it does not fix the issue. This is a bug with the BuzzTV XR 4000 software itself that you need to fix. This is NOT an issue with the provider but the box itself I have tried multiple providers and I get the same issue weather I use a portal m8u file. It is most definately a bug with the box. The sound just randomly cuts out randomly the video will be there and there will be no sound the way to fix it is to change the channel up one channel and then back to the channel you are watching again and then you have sound again for a while then randomly it will cut out again at random times. This really needs to be fixed please fix this immediately. 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted September 15, 2022 Share Posted September 15, 2022 5 minutes ago, TheGhost said: This issue is STILL occurring this issue has not fixed. I reported this back in 2021 and the problem still exists today. My Buzz TV XR 4000 is still experiencing the same issue the box is upgraded the latest version of Buzz TV as well. My Buzz TV Firmware is V20211111 and Current IPTV Version 4.0.530 When I do an update it says it is the latest version is installed Also do NOT tell me to reset the box I have already did that multiple times and it does not fix the issue! I have already factory reset it multiple times and it does not fix the issue. This is a bug with the BuzzTV XR 4000 software itself that you need to fix. This is NOT an issue with the provider but the box itself I have tried multiple providers and I get the same issue weather I use a portal m8u file. It is most definately a bug with the box. The sound just randomly cuts out randomly the video will be there and there will be no sound the way to fix it is to change the channel up one channel and then back to the channel you are watching again and then you have sound again for a while then randomly it will cut out again at random times. This really needs to be fixed please fix this immediately. You are on old software Get it updated and maybe an attitude change too 1 Quote Link to comment Share on other sites More sharing options...
